Ecom ECDA2000 Control
Control module for Ecom ECDA2800 UV-VIS PDA detector
The control module enables direct control of the Ecom ECDA2800 UV-VIS PDA detector over USB or LAN. The user can easily create the detector control method from the Method Setup - Acquisition and Method Setup - PDA tabs. All of the detector method parameters are then saved and can be added as a part of the report. The actual signal of the detector can be monitored and partly controlled from the Device Monitor window. Control is realized via a standard PC serial port using the specified cable (based on the communication type selected).
The control module was developed by the ECOM company, any further information, including the control module manual, may be obtained from the ECOM company.
ECOM
Request a Quote
Ecom ECDA2000
Controlled instrumentsEcom ECDA2800 UV-VIS PDA detector
Communication interfaceUSB or LAN
PurchasingLC Control (p/n A24) - required
Related productsClarity (p/n C50) - required
PDA Extension (p/n A29) - required
CableUSB A-B (p/n SK06) in case of serial interface (Virtual COM Port)
or
LAN Cross (p/n SK08) in case of LAN interface
