How to print and export results
Ensure that you have selected the NGA Instrument Type in the System Configuration window as described in the chapter "How to perform first calculations"
To print the data from the NGA Extension, open the Report Setup window by clicking the menu File - Report Setup… in the Instrument window or in the Chromatogram window.
On the left side, select the NGA tab. By clicking the Print check box you enable other controls of the pane. By selecting other options you can configure what information are printed.
Settings from the Report Setup are then used in the print output and preview which is accessible from the File menu of the Instrument window and the Chromatogram window.
For more details see also chapter Report Setup (NGA)
Export
Open the Setting - Export Data… menu in the Instrument window. Set the NGA Results and NGA Summary check boxes if you want to include those tables in the exports. Settings in this window are then used in the Single Analysis - Post Run Settings tab.
