Template Method
The template method parameters need to be set (opened) in the Instrument window. These parameters are used for measuring and evaluation of new data and can be edited normally in the Method Setup dialog.
Refer to the
Calibration parameters
The calibration is defined by the sequence and other options are not supported by the instrument using the EA mode. The Method Setup - Calculation tab is therefore missing.
Integration parameters
The integration parameters in the Method Setup - Integration dialog are best set from already measured chromatogram:
- Open the chromatogram in the Chromatogram window and switch to the Integration tab.
- Select the whole Integration Table using the Ctrl + A shortcut and copy its contents to the clipboard using the Ctrl + C shortcut.
- Open the Method Setup - Integration dialog.
- Again select the whole Integration Table using the Ctrl + A and paste the contents of the clipboard using the Ctrl + V.
The whole operation can be also performed by using the Method - Save as Template... command from the Chromatogram window. Another filename then the name of the method already opened on any Instrument has to be used for the template method.
