VICI Valco Valves Control
Control module for the VICI Valco valves
The Valco Valves Control Module enables direct control of the VICI Valco valves mounted on two-position microelectric actuator, multiposition microelectric actuator or universal actuator over serial line. Direct control means that the valves can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms.
Control is realized via a standard PC serial port using a specified serial cable. An optional USB - RS232 converter MultiCOM (p/n MC01) is available for computers with insufficient number of COM ports.
Request a Quote
VICI Valco Valves
Controlled instrumentsAny valve mounted on two-position microelectric actuator, multiposition microelectric actuator or universal actuator.
Communication interfaceRS232
PurchasingLC Control (p/n A24) or
GC Control (p/n A23)
Related required productsClarity (p/n C50)
Cablespecial (p/n SK17 - see manual)
