Spark SP240 Control
The Spark SP240 control module allows for direct control of the column oven over LAN interface.
With its state-of-the-art technology, user friendliness and precise temperature control, the SP240 column oven is the perfect fit for any HPLC or UHPLC application. Its capability to hold three columns and easy column switching using the column selection valve, and the option to add an active or passive pre-heater into your SP240 column oven makes you experience stable retention times with every sample you run.
The control module for the column oven allows to operate the thermostat from the environment of the Clarity software covering all possible column oven features. The method used during the analysis is saved in the measured chromatograms.
This module was developed by the Spark Holland company.
Windows 10 or higher is recommended. The control module is not supported on 32-bit Windows.
| Spark SP240 column oven | |
| Communication interface | LAN |
| Purchasing | LC Control (p/n A24) |
| Related required products | Clarity (p/n C50) |
| Connection | LAN Cross (p/n SK08) |
Compatibility of Clarity version with Spark SP240 driver
| Clarity version | Driver version |
| 10.1.2 - 10.2.0 | 1.0.8 |
| 10.1.1 | 1.0.7 |
