Testa Analytical Solutions Flowmeter Control
Control module for the Testa Analytical Solutions Flowmeter
The Testa Analytical Solutions Flowmeter control module allows for direct control of the device over USB interface.
The Testa Analytical Solutions flowmeter is designed for continuous measurement of flow rate without interference in liquid chromatography systems. These flowmeters are compatible with all HPLC and GPC/SEC solvents, are conveniently sized and powered from a USB connection. The flowmeter continuously measures the flow rate of liquids using sensitive, non-invasive sensor technology and advanced electronics to make its operation robust, reliable, and easy.
Testa Analytical offers a full range of liquid flowmeters covering the measurement of liquid flows from nanoliters per minute to 650 milliliters per minute.
This module was developed by the Testa Analytical Solutions company.
Windows 10 or higher is recommended, only works on 64-bit Windows versions.
Request a Quote
   Testa Analytical Solutions LC flowmeter
Communication interfaceUSB
PurchasingLC Control (p/n A24)
Related required productsClarity (p/n C50)
ConnectionUSB A-C
Compatibility of Clarity version with Testa Analytical Solutions Flowmeter driver
Clarity versionDriver version
10.1.1 - 10.2.01.0.47.0
10.1.01.0.44.0
