ACchrom S6000
The ACchrom S6000 Control module allows for direct control of ACchrom S6000 HPLC System. The control is performed via USB.
The control module allows the digital acquisition of the detector signal and direct control of the system pumps, column oven and autosampler. The user can easily create control method from the Method Setup - LC Gradient, Method Setup - Acquisition, Method Setup - AS and Method Setup - Thermostat tabs. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of the detector can be viewed during the analysis in the Data Acquisition window.
The control of ACchrom S6000 HPLC system is exclusively available from ACchrom company.
| ACchrom S6000 Control | |
| Communication interface | USB |
| Purchasing | LC Control - (p/n A24) AS Control - (p/n A26) - when autosampler is present PDA Extension - (p/n A29) - when DAD detector is present |
| Related required products | Clarity (p/n C50) |
| Cable | USB A-B (p/n SK06) |
| List of controlled subdevices of the ACchrom S6000 HPLC system: | |
| Detectors | 6410 UV, 6420 UV-VIS, 6430 PDA, 6440 FLD, 6450 RID |
| Pumps | 6110 |
| Autosamplers | 6210 |
| Column Ovens | 6310 |
