Ecom Flash 12 DAD Control
The control module enables direct control of the Ecom Flash 12 DAD detector over serial line. The user can easily create the detector control method from the Method Setup - Acquisition and Method Setup - PDA dialogs. All of the detector method parameters are then saved and can be added as a part of the report. Actual signal of the detector can be monitored and partly controlled from the Device Monitor window. Control is realized via a standard PC serial port using a specified serial cable.
The control module was developed by ECOM company, any further information, including the control module manual, may be obtained from ECOM company.
| Ecom Flash 12 DAD Control | |
| Controlled instruments | Ecom Flash 12 DAD detector |
| Communication interface | RS232 |
| Purchasing | LC Control (p/n A24) - required |
| Related products | Clarity (p/n C50) - required PDA Extension (p/n A29) - required |
| Cable | Serial cross DB9F-DB9F (p/n SK01) |
