HTA Autosampler Control
The HTA autosampler control modules allow for direct control of the instruments over LAN interface. Direct control means that the autosampler can be completely controlled from the Clarity environment - all autosampler parameters can be sent to the sampler directly from the computer, the sequence table can be planned and edited in the Clarity software and the order of the individual vials is directed by Clarity. Specific methods may be assigned for different vials in the same sequence and particular method used for the given sample will be saved in the resulting chromatogram.
This module was developed by the HTA company.
Windows 10 or higher is recommended. The control module is not supported on 32-bit Windows.
There is an existing alternative of a native driver for 2x00H and 3x00A autosamplers over the 64-bit Windows limitation - for that the sampler must be switched to the compatible protocol version (see particular manual on relevant page).
| HTA autosampler control | |
| Controlled instruments | 2000H, 2000HT, 2100H, 2800T, 3000A, 3100A, 3200A |
| Communication interface | LAN |
| Purchasing | AS Control (p/n A26) |
| Related required products | Clarity (p/n C50) |
| Connection | LAN Cross (p/n SK08) |
Compatibility of Clarity version with HTA autosampler drivers
| Clarity version | Headspace driver version | Liquid driver version | SPME driver version |
| 10.1.2 - 10.2.0 | 1.0.0.35 | 1.0.0.26 | 1.0.0.25 |
