Shortcuts
MS Windows shortcuts:
Enter
Applies or implements the selected command. The command that has been selected will be highlighted in the menu; in a dialog the borderline of the button will be emphasized by a continuous or broken line).
From the menu the required command can be selected using the cursor keys, and from a window using the Tab key.
Esc
In a dialog, the Esc key substitutes for the Cancel key and will close a dialog without saving the changes.
Hides an expanded menu.
Tab
Gradual selection of commands, parameters, edit lines and buttons in the active window. A selection is usually completed using the Enter key.
Space bar
Rapidly switches between selected parameters by checking or unchecking them.
Alt
Selects the first menu item.
Alt + letter
Rapidly selects a command or parameter that has the selected letter underscored.
| Shortcut | Command from menu | Description | Validity |
| F1 | Help | Open new Help window | Everywhere |
| F2 | Edit | Enter into edit mode of the selected cell | |
| Ctrl + N | New file | Create a new file | |
| Ctrl + A | Select all items in the list/table | ||
| Ctrl + O | Open | Open file | |
| Ctrl + S | Save | Save file | |
| Ctrl + Shift + S | Save As... | Save file as | |
| Ctrl + W | Close | Close current file | |
| Ctrl + Shift + W | Close All | Close all opened files | |
| Ctrl + P | |||
| Ctrl + X | Cut | Cut selected values | |
| Ctrl + C | Copy | Copy selected values | |
| Ctrl + V | Paste | Insert from clipboard | |
| Ctrl + Z | Undo | Cancel the last command | Tables |
| Ctrl + Shift + Z | Redo | Repeat the last command | |
| Delete | Erase the table field | ||
| Alt + ↓ | Work when cell contains , the shortcut opens corresponding options. |
| Ctrl + E | Automatic export of data from Chromatogram window according to settings in Export Data dialog | Chromatogram | |
| (Ctrl) + F7 | (First) Previous | Browse through chromatograms: open the previous (fist) chromatogram from the current directory. | |
| (Ctrl) + F8 | (Last) Next | Browse through chromatograms: open the next (last) chromatogram from the current directory. | |
| Ctrl + - | Previous Zoom | Display the previous cut-out | Chromatogram
Calibration Data Acquisition |
| Ctrl + + | Next Zoom | Display the next cut-out | |
| Shift + Mouse wheel | Move the cut-out Left & Right | ||
| Mouse wheel | Move the cut-out Up & Down | ||
| Ctrl + Mouse wheel | Zoom In/Out | ||
| + | Zoom In | Enlarge graph | |
| - | Zoom Out | Reduce graph | |
| Ctrl + Shift + Mouse wheel | Enlarge/reduce the cut-out of the chromatogram in the dimension of the Y-axis only | ||
| Ctrl + * | Unzoom | Display graph in original size | |
| Ctrl + R | Run Single | Start an analysis | Data Acquisition |
| Ctrl + Q | Start, Run Sequence | Start a sequence | Sequence
Data Acquisition |
| Ctrl + Space bar | Pause / Resume | Pause a sequence / Resume running of a set sequence | |
| Ctrl + B | Abort | Immediately terminate a sequence | |
| Ctrl + H | Snapshot | Process the sample currently being measured without terminating the analysis | |
| Ctrl + T | Stop | Terminate a sequence after the completion of a sample measurement | |
| Ctrl + ↓ | Skip | Skip the current sample | Sequence |
| Ctrl + ← | Repeat Injection | Repeat an injection from the current vial | |
| Ctrl + E | Reset Status (Status) | Reset the flags in the Status column |
