Offline - Batch reprocess
Batch opening and processing of chromatograms can be used for “ex-post” validation that works similarly to simple opening of chromatograms in the Chromatogram window with the Overlay mode enabled.
Use batch opening if you want to batch adjust opened chromatograms prior to a validation, otherwise opening chromatograms in the Chromatogram window is more suitable (for more details see also chapter Offline - Manual)
- Open the SST method in the Chromatogram window using the SST - Open command.
The Overlay mode in the Chromatogram window must be enabled.
- Switch to the Instrument window and open the Batch dialog using the Analysis - Batch... command.
- In the Batch dialog, select the chromatograms intended for the validation.
The Open in Chromatogram Window checkbox must be selected!
- Using the Proceed button will run a batch processing of selected chromatograms.
- All batch-processed chromatograms will be automatically opened in the Chromatogram window.
- You can view the validation result on the SST Results tab.
