View
This section contains commands used to set up the appearance of the Chromatogram window.
| Command | Description |
| Toolbars | Displays commands for toolbars. The command is similar to the Toolbars command in the main
Note: Reset All does not display hidden toolbars. To show them invoke Customize... - Toolbars menu. |
| Maximize Graph | The command maximizes the graph to cover the entire window (hides the bottom tabs). Double click near the splitter (the cursor will change to ) to achieve the same effect.
| Show Both | Used to display both parts of the window (the chromatogram and the tabs). |
| Maximize Tables | The command maximizes the bottom tabs to cover the entire window (hides the chromatogram). Double click near the splitter (the cursor will change to ) to achieve the same effect.
| Show Tables |
Opens a submenu for showing or hiding tabs in the Chromatogram window. Tabs with a checkmark are currently displayed. Either the Results or All Signals Results tab must always remain visible - at least one of them cannot be hidden. |
