Print Setup
You can open the Print Setup dialog by using the Print… command, pressing Ctrl + P, or clicking the Print… button in the Report Setup or Print Preview dialogs. This dialog is used to select the printer and adjust basic printing options. Its layout may differ depending on your version of Windows and local settings.
Clicking the
icon on the toolbar prints the report immediately using the current settings.
If no printer is installed in Windows, the Print and Print Preview commands are disabled.
Print Setup
Printer options
Here you can choose the printer, check its status and open the printer Properties.... Changes made in Print Setup dialog are reflected in Properties dialog and vice versa.
Paper and Orientation options
These settings (paper size and source, orientation) only apply to the currently selected printer. If you change the printer to one that does not support the chosen paper size, the closest available size is selected automatically.
All these settings are saved to *dsk file.
