Local Table Menu
Local menus contain frequently used commands relevant for the given table. Local menus can thus vary, according to the table you are currently editing. In the following overview commands common for most tables are described:
Selects all cells in the table. Also available by using the Ctrl + A shortcut.
Copies selected cells to the clipboard. Also available by using the Ctrl + C shortcut.
Pastes the content of the clipboard into the selected cells of the table. Also available by using the Ctrl + V shortcut.
Restore Default Columns
Restores the default columns and fonts for a given table. A detailed description of this function is in the chapter "Edit"
Setup Columns…
Invoking the Setup Columns… command opens the Setup Columns dialog, where it is possible to change the appearance and order of table columns. Detailed description of this dialog can be found in the chapter "Setup Columns"
To access the setting of user columns the user must be authorized to edit methods. See the Edit Method checkbox in the User Accounts dialog.
User Columns
Submenu of commands enabling to handle user columns in the full version. The available commands are:
Add…
Use this command to add a customized user column to the table. Invoking this command will open the Add User Column dialog, whose detailed description can be found in the chapter "Add User Column "
Edit Selected…
Invoking this command will open the Edit User Column dialog for the active user column. It is used for modifying of the content of the user columns.
Delete Selected
Invoking this command deletes the active user column or columns.
Delete All
Deletes all previously added user columns. A detailed description is in the chapter "Edit"
Hides the selected columns.
Shows all hidden columns.
