Import Chromatogram…
Imports a chromatogram in AIA, Text or EZChrom ASCII format. The Text files are supported with *.txt, *.chr and *.csv suffixes. Select the Open Files to Import dialog using the File - Import Chromatogram… command. Select the desired directory and one or more files to import. The files displayed may be filtered using the filter in the File Type listbox.
Imported chromatograms are processed using the current method from the
Import of several files simultaneously
You may select a number of files simultaneously in the Open Files to Import dialog. The Import Text File or Import AIA File dialogs will open progressively for each imported file according to the type of imported file. If all the selected files share the same format, it is possible to import them all at once with the same settings.
Import of multi-detector chromatograms
The Import Chromatogram… dialog can import multi-detector chromatograms from *.TXT or *.CHR format.
