Stopping a running sequence
To set a sequence follow the same procedure as described in the chapter "Online - Sequence (or Single Analysis)", inserting the following two steps after the setting of the Overlay mode:
- Select the SST - Events... command in the Chromatogram window.
- In the displayed SST Properties - Events dialog select the Stop Sequence in the If SST result is FAILED section.
Stopping a sequence can be also done together with other pre-defined action, such as running a program, sending an e-mail etc.).
