Storing results in DBF
Results saved in a database file can be freely used, for example, for a system validation according to special validation methods, to monitor trends in results, etc.
Setting of the Overlay mode has no effect on results saved in the database file.
- Open the SST method in the Chromatogram window using the SST - Open... command.
- Open the SST Properties - General dialog using the SST - General... command.
- Here, select the Log SST Result into DBF file and fill-in the database file name into the File Name field.
- Use the Clarity station either online (measuring) or offline (opening of saved chromatograms) to validate the desired chromatograms and save the results into the *.dbf file.
Only validation results of chromatograms opened in the Chromatogram window will be saved in the database file.
- Open the created database file in the database program. The database file is automatically created in the current project directory.
If you open the database file in another program, the SST Extension cannot write into it. Work with the database file only after completing work with Clarity, thereby avoiding an unwanted locking of the file while saving results.
