Validating multi-detector chromatograms
When using multi-detector chromatograms, it is possible to select which signal will be used for SST evaluation.
Chromatogram - SST Results - Multi-detector evaluation
In the header of the Parameters Table on the SST Results tab will appear the Evaluate combobox with following options: Active, Signal 1, .., Signal n.
The default Active option will evaluate the signal that is currently active in the Chromatogram window across all opened chromatograms.
Choosing a specific signal such as Signal 2 will evaluate signals that are on the second place across all opened chromatograms.
The name of the active signal is indicated in the window header and its description in the graph legend is highlighted in bold letters.
