DBF file structure
Each validated chromatogram is saved separately, a separate row is created for each monitored parameter. Columns irrelevant to a given parameter remain empty.
The database file is automatically created in the current project directory.
Description of individual columns (category):
| Column | Description |
| CHROM_NAME | Chromatogram name (including path, if applicable). The CHROM_NAME field is designed for 256 characters, so the entire name will fit. It can, however, happen that in MS Excel, for example, only the first column of an open *.dbf will be displayed - other columns being beyond the screen size. |
| DATE | Date of the validation. |
| COMPONENT | Component name. |
| PARAM_NAME | Parameter name. |
| LO_LIMIT | Lower limit. |
| HI_LIMIT | Upper limit. |
| VALUE | Parameter value. |
| RESULT | Validation result (in the selection PASS, FAIL, UNKNOWN). |
Working with *.dbf files in MS Excel is described in detail in the chapter "Using DBF in MS Excel"
