Remove Generated Signal
This command is located in the Chromatogram window in the menu Chromatogram.
The Remove Generated Signal command is used to invoke the Remove Generated Signal dialog where generated signal can be removed.
Only named signals can be removed. Currently, it is not possible to delete only one signal (except for the last one), every signal following the one selected for deletion will be also deleted.
