Sequence
- Use the File - New command or the
icon in the Sequence window to create a new sequence. - Name the sequence in the Save As dialog.
- The new sequence is created as a copy of the EATemplate.seq file stored in the COMMON subdirectory of the Clarity folder (C:\CLARITY\DataFiles\COMMON by default). If this file is missing, default program parameters will be used.
You can store the common part of your sequence (most commonly the sequence options and the initial standards with first sample row) to this file.
- Set the method to sequence by using one of the following:
- After clicking in the cell in the Method Name column the
icon will appear. Using it invokes the dialog where the method can be selected. - The method can be directly input by typing the method's name in the cell in the Method Name column.
- Add new rows to the Sequence Table by clicking the checkbox in the Run column on the last empty line or editing any of its fields.
- Fill in the standards and samples to be measured.
- Measure the Sample Weight of the samples. Use Get Weight dialog in the case you are using configured Balance.
- Run the prepared sequence (using the Run Sequence command (or
icon) from the Sequence window) to process the samples.
It is recommended to create a new sequence for each set of measurements (daily work, series of samples), instead of reseting the measured one.
All the samples in the sequence refer to a single calibration file.
