Calibration setup
For each new sequence a calibration file with identical name (*.CAL) is created in the calibration subfolder (CALIB by default) of the current project.
This calibration will be based on the calibration template EATEMPLATE.CAL file stored in the Clarity Common folder (C:\CLARITY\DataFiles\COMMON by default). Display and edit the calibration in the Calibration window.
The retention times need to be set according to your actual standard - they will differ according to the instrument type and conditions used. The Identification Windows should be set wide enough to accommodate the differences in retention times for different element amounts.
The dominant peak (usually carbon) type can be set to Refer, the identification windows for other peaks will be shifted accordingly.
Linear Curve Fit Type will usually be used with Area as Response Base.
