Sequence window
Sequence window now contains new columns of the elemental compound percentages in standards, i.e. Nitrogen, Carbon, Hydrogen, Sulphur, Oxygen.
Sequence window
Sample Weight
Replaces the Sampe Amount column in Clarity standard mode. The Weight measured on the Balance is automatically inputed here alternatively the field can be modified manually. This value is propagated to the Chromatogram and its Summary Table.
EA Sample Type
Replaces the Sample Type column in Clarity standard mode. It works basically the same, only Standard has some special conditions. The available entries are:
| Sample Type | Description |
| Unknown | For unknown samples. |
| Standard | For calibration standards. Sample Amount, Level (Lvl.) and EA Standard Name fields must be filled in. The composition columns will be filled automatically from the Standard Table. |
| Blank | For blank samples. The response determined will be used on Level 21 of the calibration with amount 0, which will be counted to the calibration. |
| Bypass | Allows for performing an analysis in the Active sequence with controlled autosampler without actually injecting a sample. This is useful for running the column-cleaning or equilibrium-setting sample, etc. |
Method Name
Contains the method name for the current method. This method is automatically set for all rows in the sequence and can't be changed during the running sequence as the column is disabled.
To change the method while the sequence is running, stop the sequence, change the method in any not measured row and resume the sequence. Only a user with the access right to Select Method can select another method.
