GL Sciences LC800
Control module for the HPLC system
The GL Sciences LC800 HPLC Control module allows for direct control of the HPLC system over USB. The system may include pumps, detector, column oven (LC Control licence) and autosampler (requires AS Control licence).
All parameters including parameters controlling pump behavior in the Idle state, acquisition conditions or temperature program are a part of the method. Therefore it is possible to create various acquisition methods and choose between them only by loading the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent Device Monitor.
A single Clarity station can only control a single LC800 HPLC system.
GL Sciences LC800
  GL Sciences LC800 Control
Communication interface USB
Purchasing LC Control (p/n A24)
AS Control (p/n A26) - optional
Related products Clarity (p/n C50)
Cable USB A-B cable (p/n SK06)
  List of controlled subdevices of the GL Sciences LC800 HPLC system:
Detectors LC800 UV-VIS Detector (UVD), LC800 Electrochemical Detector (ECD), Laser-Induced Fluorescence Detector LIF726 and 727 (LIF)
Pumps LC800 High-Pressure Gradient Pump, Auxiliary Pump PU712B
Autosamplers LC800
Thermostats LC800
