Clarity Lite compared to Clarity
The comparison table shows the differences between Clarity Lite and Clarity.
Clarity Lite is a simplified version of Clarity that provides data acquisition from one chromatograph (using one A/D converter with up to four detectors sharing a common time-base). With its reduced set of functions Clarity Lite is an inexpensive solution for legacy detectors. Clarity Lite can be anytime later upgraded to Clarity.
Support of multiple detector instruments |
32 detectors / instrument | 4 detectors / instrument |
Number of instruments connected simultaneously |
1 - 4 | 1 |
Results Summary Table |
Full history record including calibration data saved in the chromatogram |
1-4 | 1 |
Time programmable integration parameters Peak Width and Treshold |
Supporting tools for 21CFR Part 11: |
- Electronic signature |
- Audit trail |
- Advanced user accounts |
Control modulesRefer to List of Controlled Instruments |
Extensions(SST, PDA, GPC, CE, EA, NGA, DHA, MS) |
System Suitabilty Module - SST |
Column Performance Table |
User columns in Result tableSpecial calculated columns defined by the user |
"Directories" command for selecting the working folder for data saving |
Archive/restore functions |
Batch processing |
"Model method" and "Copy From template" commands for extended work with method files |
Postrun |
Single Analysis mode |
Sequence preparation and measurement |
ISTD and ESTD calculation methods |
Reference peaks usage |
Automatic software update from Internet |
Automatic subtraction of solvent defined in the method |
Display background chromatogram in the Data Acquisition dialog |
Installation qualification (IQ) protocol |
