Saving the chromatogram method as a template method
Each chromatogram contains saved copy of the method used for acquisition of such chromatogram. However, changes done in Chromatogram window (e.g. Description, Integration Parameters, linked Calibration File...) are not updated in the original method used for acquisition nor processing. To amend your method accordingly, you can create template method from the method in chromatogram, which is useful after optimizing integration parameters.
  1. Open the chromatogram with optimized method.
  2. Select the Method - Save as Template… to save the method (including the changes made by you) from the current chromatogram as a new method, or for example overwrite (update) your acquisition method.
It is not possible to overwrite any method that is currently in use, for example a method opened on any Instrument.
