Data Acquisition - Simulated
The title "Simulated" is displayed. The
▌Reason 1: You are using Clarity Demo version.
Solution:
Then use the correct Clarity installation to install the full version.
▌Reason 2: A DEMO detector is allocated to the Instrument.
Solution:
Open the System Configuration dialog from the Clarity window using the System - Configuration... command and check the tab of the corresponding Instrument - Instrument X. If it obtains detector signals only from the DataApex DEMO detector, it is necessary to reconfigure it. You can find more information on how to add a detector in the chapter "Clarity Configuration"
