Standard cable for Colibrick
The standard Colibrick cable for one detector
Signal cables
The cables labeled as “DET1” to “DET4” (corresponding to the number of channels) are supplied without connectors with stripped and tinned endings - red/brown (+), white (-), and shielding (analogue ground).
Starting (marker) cables
The cables labeled as “IN1” to “IN4” (corresponding to the number of channels) come with an RCA connector. Each starting cable contains two more cables: one with either free leads [red (+), shielding (digital ground)] for a direct connection to the chromatograph, or a valve for a valve-mediated connection, and one equipped with a push-button for the cases when there is not a starting contact available and it is necessary to perform a manual start.
Digital output cables
Relay contacts labeled as "OUT 1R" to "OUT 4R" (corresponding to the number of channels) terminate with free leads. These are used for the autosampler (AS) synchronization in an active sequence without the AS Control module.
Each Colibrick comes with a female CANNON SUB D 37-pin connector.
