Edit
Submenu of commands for working with the clipboard and tables.
| Copy | Invoking the command or using the Ctrl + C shortcut copies the selected text into clipboard. |
| Select All | Invoking the command or using the Ctrl + A shortcut selects all fields of the table. |
| Restore Default Columns | Invoking the command returns the display of the given table to default settings (for more details see also chapter Edit) |
| Setup Columns… | Using this command opens the Setup Columns dialog which allows to set the visibility and order of appearance of columns in the given table (for more details see also chapter Setup Columns) |
| Hide Column(s) | Invoking the command hides all selected column(s) from display (for more details see also chapter Edit) |
| Show Hidden Column(s) | Using this command displays columns hidden by the Hide Column(s) command (for more details see also chapter Edit) |
