Remove Generated Signal
This command is located in the Chromatogram window in the menu Chromatogram.
The Remove Generated Signal command is used to invoke the Remove Generated Signal dialog where generated signal can be removed.
Only named signals can be removed. In case there are more generated signals in the chromatogram, with the one selected in this dialogue will be also removed all newer ones.
