Add MS Spectrum to Library
Dialog invoked by using the Add Spectrum to Library  menu command, serving for saving the spectrum into the user library.
Add MS Spectrum to Library dialog
The dialog allows the user, prior to sending the spectrum into the library, to set several parameters. The spectrum is sent to the MS Search external program after pressing the OK button.
Retention Time [min]
Shows the retention time of the spectrum taken in minutes.
Serves for assigning a name to the spectrum when it is sent to the MS library. If the field is left empty, the retention time will be used instead.
Serves for setting the time interval in which the spectrum will be calculated as an average spectrum. The value entered into the field is the whole width of the interval.
