Chromatogram window in EA Extension
The Result Table in the EA Extension Chromatogram window has two additional columns performing EA calculations. These columns are:
Displays the ratio of the carbon amount to the given row's element amount.
Carbon Amount Ratio = Carbon Amount / Element (C,H,N,...) Amount
Displays the ratio of the given row's element response to the carbon peak response, be it Area or Height. The column is hidden in the default desktop.
Carbon Response Ratio = Element (C,H,N,... ) Response / Carbon Response
The Summary Table in the EA Extension Chromatogram window now contains the column Sample Weight (formerly named as Sample Amount).
The Results pane in the EA Extension Chromatogram window in the Common for All Signals section now contains the field Sample Weight (formerly named as Amount).
